Multiple IP to one WAN port
Dear All,
I have a ZyWall 110. From ISP I'v got a 12 public IP range (mask: 255.255.255.240). I need to get them all to WAN1 port.
I'm absolute beginner ZyWall user, so please help me. What IP adress need to be the WAN1 interface, how trunk the all address. After configure the WAN and LAN, I have to make 2 site-to-site VPN connection too
Every help welcome
Tamas from Hungary
Every help welcome
Tamas from Hungary
As I see, the ZyWALL automaticaly use them.
Sorry for dumb question
T.1 -
So how you getting their Public IP's? With the WAN port connected to your modem do you get one of the public IP's? Or some other IP?
Are you looking to have your LAN with these Public IP's or use 192.168.1.xxx and NAT them to the Public IP's?
Hi PeterUK,
I get them all to WAN1 from ISP's modem.
I have 3 local VLAN 192.168.180-181-182 for LAN, Management and Guest.
For LAN VLAN I set DHCP server, but unfortunately my PC can't get IP.
Thx
Tamás0 -
Hi @Achro,Can you see DHCP packet coming to ZyWall110 Lan/VLAN interface ?If you cannot see client send DHCP request packet on ZyWall110 Lan/VLAN interface.You can check downlink switch VLAN settingPacket capture for DHCPRouter> packet-trace interface ge3 extension-filter port 67 or port 680
Zyxel_Cooldia,
Yes the request packets are coming, but no reply packet
THX
Achro
UPDATE: I change the policy settings and now it works!
So my VLANs and internet connection are working.
But ...
I have a web server too. My WAN interface address is x.x.x.205. The web server's public address is x.x.x.193, local address is 192.168.180.50 and it is in VLAN5.
How the hell can I set working NAT and policy rules and the two public address.
I'm afraid I need to set up an external VLAN as well, but what IP address do I need for the WAN port if the external VLAN is x.x.x.192 / 28?
THX0 -
Hi @Achro,Do you mean two public IP Source NAT for 192.168.180.50(Outbound) or Destination NAT(Inbound)?As for second question, there is no need to set up vlan for this. Just pick a valid public IP for device wan interface.0
Dear @Zyxel_Cooldia,
I have IP range x.x.x.192/28 :Broadcast: x.x.x.207
HostMin: x.x.x.193
HostMax: x.x.x.206
Def. GW: x.x.x.206
Netmask: 255.255.255.240
I would like to use them all.
Our sit2site VPN is x.x.x.205 and this is the WAN1 port's IP now, I can ping it, but I can't the x.x.x.193, whitch is the web server's public IP.
THX
T.
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
