Zyxel USG 60 W throughput
Dovetail_MD
Dovetail_MD Posts: 81 image  Ally Member
edited April 2021 in Security
Good afternoon all,
We are wondering why we getting a slow speed on in our network.
The incoming supply is running at about 160 MBPS is measured by plugging a laptop straight into the incoming router i.e. on the outside of the DMZ whereas on a workstation we are getting about 60 MBPS.
The switches between the USG 60 W and our office are both running at gigabit and the wiring interconnects are a mixture of fibre and CAT7
Any thoughts team?
«1
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,568 image  Zyxel Employee
    With UTM feature enabled, traffics are thoroughly scanned by USG, it would have effect on performance.
  • Dovetail_MD
    Good morning
    Thank you for your reply
    Really as much of a hit to knock the speed down by 50%?
  • Zyxel_Cooldia
    Hi @Dovetail_MD,
    It is possible when all UTM features are enabled.
  • Zyxel_Cooldia
    For better performance with UTM enabled, ATP-100W would be suitable for your site.
  • Dovetail_MD
    Good morning
    Thank you - I guess we could use a simple firewall rather than one with modem facilities as we have a modem from our broadband supplier which does simple NAT
    But does this simplification really improve throughput?
    Best wishes
    Andy
  • Zyxel_Cooldia
    Hi @Dovetail_MD,
    The throughput will be higher  if it just runs as a pure NAT router without UTM services. However, your network will lose the protection from USG instead. It depends on what purpose you want to achieve in your network environment.
  • Dovetail_MD
    You misunderstand
    The vendor's router does NAT - I'm asking if no NAT and perhaps no wifi on the ZYXEL inboard of that will help speed
  • Dovetail_MD
    And perhaps if Zyxels had more processor grunt the hit of UTM would be less?
    PeterUK Posts: 4,264 image  Guru Member
  • Zyxel_Cooldia
    @PeterUK, True, It will have performance improvement if we uncheck collect statistics.
    @Dovetail_MD, UTM service is the most CPU power consuming application, even though if you only enabled the UTM function without NAT, the improvement will still be limited
