IGMP multicast VLAN more than 15 VLANS
UNetworksIT
UNetworksIT Posts: 6 image  Freshman Member
edited July 2024 in Switch Ideas
When enabling IGMP feature for multicast traffic you can define up to max 15 VLANS.
For larger environments this is way to low. HP, CISCO,... provides more VLANS.
Please expand this maximum!!
0 votes
Declined · Last Updated
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited July 2020
    Hi @UNetworksIT
    Welcome to Zyxel community.
    For starters, we'd like to know which model you're using?
    And, how many VLANs do you desire expanding to?
    Zyxel_Lucious
  • UNetworksIT
    Hi Lucious,
    We use the XS3800, XS3700 as main core switches (those have all our VLANS).
    In our other switches we use the XGS2210-28 en 52.
    I don't know what the possibilties are at your side... but if we can double the number to for ex 30 VLANS in the IMGP or go to 50 then that would be a hughe step forward.
    Cheers
    Geoffrey
  • Zyxel_Lucious
    @UNetworksIT
    In our experience, up to 15 IGMP snooping VLANs should handle most of our cases.
    If possible, could you describe your application/scenario for us?
    Sincerely,
    Zyxel_Lucious
  • UNetworksIT
    Hoi Lucious,
    We are a EDUCATIONAL CAMPUS and have 3 sites
    Per site we have VLANS below.
    The campus switches covers all VLAN's. Our servers are connected to all VLAN'S
    The IGMP is for the (EDUCATION-1-4 + ADMINISTRATION + WIFIDOMAIN)*3 + SERVER VLAN = 19 VLANS
    - VL MGMT
    - VL EDUCATION-1
    - VL EDUCATION-2
    - VL EDUCATION-3
    - VL EDUCATION-4
    - VL ADMINISTRATION
    - VL ICT
    - VL CAMERA
    - VL VOICE
    - VL WIFI DOMAIN
    - VL WIFI STAFF
    - VL WIFI STUDENTS
    - VL WIFI GUETS
  • Zyxel_Lucious
    edited July 2020
    @UNetworksIT
    1.
    Could you confirm that the multicast streaming running in all of 19 VLANs all the time?
    2.
    If so, it seems to us that "IGMP router" would be better for your scenario to do IGMP routing task without VLAN number limitations, i.e. you don't have to configure all VLANs on every switch.
    The feature is available on our L3 switch XGS4600 series.
    Sincerely,
    Zyxel_Lucious
  • UNetworksIT
    Hi Lucious,
    We are talking about IGMP snooping... and not IGMP routing
    Tnx for your feedback.
    Regards
    Geoffrey
  • Zyxel_Lucious
    @UNetworksIT
    It was just kind of recommendation, but fine now we can focus on IGMP snooping.
    And how about my original question?
    Zyxel_Lucious
  • UNetworksIT
    Hi Lucious,
    No problem!! Yes we have multicast streaming running in all 19 VLANS all the time.
    What do you suggest?
    Tnx
    Cheers
    Geoffrey
  • Zyxel_Lucious
    @UNetworksIT
    I will PM you for further info.
