USG110 egress throughput issue
nicomac
nicomac Posts: 3 image  Freshman Member
edited April 2021 in Security
I have a Zyxel USG110 device, fully patched with the last firmware (V4.38(AAPH.0)).
Unfortunately, the egress (upload) throughput is limited to 10 mbps although my ISP is providing 500 mbps up and down.
The ingress (download) throughput is OK: 500 mbps and more.
My config is as follows:
Connected to the modem on WAN1 port.
Connected to a Gbit/sec CISCO switch on the LAN1 port.
Using PPPoE with authentication (user/password) on VLAN 835.
All Secure services features are disabled.
Security policy > Session control is disabled as well.
Any idea?
Thanks a lot...
  • Zyxel_Cooldia
    Welcome to Zyxel Community.  :)
    What is the device Wan and Lan speed/duplex mode? Or any transmit collision during you run speed test?
    CLI for Speed/Duplex mode check:
    Router# show port status
    Port    Status      TxPkts    RxPkts    Colli.    TxB/s     RxB/s     Up Time
    1       100M/Full   6782      6478      0         985       2011      00:15:19
    2       Down        0         0         0         0         0         00:00:00
    3       Down        0         0         0         0         0         00:00:00
    4       Down        0         0         0         0         0         00:00:00
    5       Down        0         0         0         0         0         00:00:00
    6       Down        0         0         0         0         0         00:00:00
    7       Down        0         0         0         0         0         00:00:00
  • nicomac
    Thanks Zyxel_Cooldia,
    Here is my show report status :
    Router> show port status
    1       1000M/Full  485931    983386    0         12549     28984     00:04:19
    4       1000M/Full  982411    485612    0         28650     11415     00:04:19
    Which looks fine, but in fact, what I did is to reset the device (with a paper clip), and put back the settings, and everything is now fine (more than 400 mbps as egress / upload).
    Thanks again to you for taking time to look at my issue.
  • Zyxel_Cooldia
    Hi @nicomac,
    Good to hear that. Feel free to let us know if the issue happens again. :)
