Locked out of USG210
jw708
jw708 Posts: 16 image  Freshman Member
edited April 2021 in Security
After updating the firmware I was asked to set a new password. I set a new password but I am unable to login.
It looks very similar to this issue: https://businessforum.zyxel.com/discussion/1393/locked-out-of-my-own-usg110
The password did not have a $ but started with '
I have a copy of startup-config.conf but is there any way to get back in without having to factory reset?
  • jw708
    Thanks @Zyxel_Emily that worked.
    I still find this whole situation absurd and have not appreciated having to spend time at the weekend to be physically next to the device to resolve this. As others have suggested, this has been enough for me to avoid using Zyxel products again in future.
    Thanks.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,470 image  Zyxel Employee
    Hi @jw708,
    Set a new password ''a12345 for admin after the password is expired when using the latest firmware, and I can successfully login as admin with the new password ''a12345.
    You can upgrade to the latest firmware and try it again
    https://businessforum.zyxel.com/discussion/4751/weekly-firmware-support-version-lab-version
