How to get access to WebUI on my GS1900-24HP?
dimasusl
dimasusl Posts: 3 image  Freshman Member
edited August 2022 in Switch
After downgrading firmware version to 2.00(AAHM.0) there is not available WebUI. I have already tried all the ways I found (hard reset, get IP via DHCP server, ZON utility), nothing help me. ZON found device, it can change IP, password, reboot, but firmware uprgade always failed (Firewall if off).
Version  2.00 (AAHM.0) is not wrong, because on another GS1900-24HP everything is ok (i need this version because there is possibility to control reset on POE ports via my software).
  • dimasusl
    Solution for me - I deleted all addresses on my network interface, leaving only one from the 192.168.1.255 subnet. And after that, ZON was able to update firmware. Then, through ZON, I reset the settings and the web interface became available
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    @dimasusl
    Welcome to Zyxel community.
    For starters, could you confirm that "hard reset" is to press reset button for over 7 secs to clear all settings?
    In case you didn't wipe out the existing setting, maybe there is "remote access control" to block certain IP from webGUI access.
    Once you confirmed factory-default the switch, its management IP should restore back to 192.168.1.1.
    1. Can you ping the switch?
    2. Try clean browser's cache, or even use different browser (older version may do the job since fw 2.00 is very old).
    3. Use another PC to try.
    Hopefully it helps.
    Zyxel_Lucious
  • dimasusl
    edited July 2020
    Yes, "hard reset" i mean that it is pressing a Reset button more than 7 seconds.
    1. I can ping 192.168.1.1
    2. I will try to clean browser's cache, but nmap says to me there are no opened ports on switch.
    3. I tried 3 different computers (powered by Linux and Windows)
  • dimasusl
