IP Reputation Filter - Blocking my website (Wix)
Hi @iSpeed,
Since version 4.55, the phishing category scan is moved from "inbound+outbound" to "inbound only", and the default setting of phishing is disabled.
If any well-known websites should not be blocked by IP Reputation, give us the list of blocked IP addresses.
We will verify if these IP addresses are safe and add them to white list in the next signature version.
[FEATURE CHANGE] IP Reputation change the phishing category scan from "The Internet And Local Networks" to "The Internet” only.
Before (4.50)
After (4.55)
What would really be helpful is if when a website is blocked by ip reputation that it notifies user in browser and an option to submit for white list. As it is it just times out and you don't know what is causing it.0
Hi @iSpeed,
Thanks for your suggestions.
The requests are in the feature queue and under evaluation by ATP team.
I can confirm this. At my whitelist I have as example:23.227.38.65 (cloudflare)My customer was not able to open website protected by cloudflare, but the requestet site was clean... so this was an collateral damage by one infected / phising site behinde the CDN with this ip...Not running 4.55 until now, I hope this will work better.
Hi @Mario,
With the latest signature version 1.0.0.20200811.0, the threat level of the IP 23.227.38.65 is Neutral, so it should not be blocked by IP Reputation.
If the website is blocked by IP Reputation, go to MONITOR > Security Statistics > Reputation Filter and check the list of IP detected.
- 441 Beta Program
- 294 Service & License
- 461 News and Release
