static route?
Hi guys,
I'm a bit of a network newbie, using a USG60.
I have following question: I have a server (internal fixed ip-adress) that we will be using for a VPN connection towards a customer based on a fixed IP-adress.
On my USG60 router, the WAN port 1 has received the fixed IP-adress. My WAN port 2 has a variable IP address at a different ISP.
In the WAN Port I have port balancing on. The WAN port balancing should be on, just to make sure that both ISP's are 'equally' loaded with traffic.
How can I make sure that my server (ip = 192.168.7.23) always uses my wan port 1 to connect to the internet (and to my customers site).
Can this be done by creating a static route?
Can someone please help me out?
Thanks in advance!
Best regards,
jornvdd
Thanks in advance!
Best regards,
jornvdd
What's you need is a policy route rule.
You can configure the rule based on source IP as your server IP address.
And the next-hop is interface wan1.
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
