NWA-1123-AC-HD: OK to upgrade 5.46 directly to 6.00?
The NWA-1123-AC-AP access points I bought came with firmware 5.46. It seems that the latest version is 6.00.
Is it OK for me to upgrade directly to 6.00? If not how should I proceed?
Any special instructions? The release notes had no great details. Thanks!
Hi @Homelab
We will retain the recent 3 firmware versions on our official website. Version 6.00 could be found.
https://www.zyxel.com/support/download_landing/product/nwa1123_ac_hd_13.shtml?c=gb&l=en&pid=20170106200003&tab=Firmware&pname=NWA1123-AC%20HD
Here are the firmware links.
5.50
http://ftp2.zyxel.com/NWA1123-AC_HD/firmware/NWA1123-AC HD_5.50(ABIN.3)C0.zip
6.10
http://ftp2.zyxel.com/NWA1123-AC_HD/firmware/NWA1123-AC HD_6.10(ABIN.2)C0.zip
Joslyn5
Hi @Homelab,
Welcome to ZYXEL Community.
Here is our suggest steps to upgrade the AP firmware.
1. Copy your current configuration to avoid if there is any unexptected error occurs.
2. Uprade the firmware to v5.50 first, then upgrade to v6.0.
Hope it helps.
Joslyn0 -
Thanks. I am finally ready to perform this upgrade. I have two questions:
- I no longer see the 5.50 firmware on the zyxel support download page; where can I find the 5.50 firmware download?
- I no longer see the 6.00 firmware on the zyxel support download page; I assume it has now been replaced with 6.10. Should I upgrade to 5.50, and then to 6.10?
PS To clarify: I have the NWA-1123-AC-HD access points
Hi @Homelab
5.50
6.10
Joslyn5 -
Thanks so much! I successfully upgraded from 5.46 -> 5.50 -> 6.00 -> 6.10
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
