GS1920-8HP PoE contol via SNMP
does someone know the OID for the enable/disable power output (PoE) on a single port via SNMP?
I've installed the MIBs:
ZYXEL-ES-COMMON
ZYXEL-ES-SMI
ZYXEL-SYSTEM-MGMT-MIB
but a snmpwalk doesn't give me clear values to find the OID for the PoE settings.
Greetings
Ben
Hi @ben_
Welcome to the Zyxel Community!
The MIB you need should be RFC3621 POWER-ETHERNET-MIB (in attached), which is standard mib that GS1920 series can support.
The OID is .1.3.6.1.2.1.105.1.1.1.3 (pethPsePortAdminEnable)
Zyxel_Lucious
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
