Zyxel USG 60 W throughput
Good morning,
Thank you for your response - But then why above suggest I buy a different device which although it will not be using Wi-Fi will be using UTM - unless that device has more grunt than the one I'm using?0 -
Hi @Dovetail_MD,Because ATP100W is the model corresponding to USG60W since both of them have built-in wifi modules, If there is no need to use wireless in your network environment, ATP-100 can also be considered.0
Good afternoon,
Thank you again.
But I'm afraid your response does not answer my question in that I have no idea if the ATP-100 has more grunt than the USG 60 W and will therefore provide more throughput or in other words slow down my Internet connection less?0 -
Hi @Dovetail_MD,
ATP-100 is the new generation platform and the result will be better than USG60W. This is lab confirmed result so that I can say it to you.The ATP-100 performance can up to more than 160 Mbps with UTM feature enable based on our lab test.
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
