USG60W and WAX AP Series (Wifi 6)
1.) is the WAX510 already supported on the USG60W ?
2.) Can i manage 2 WAX510 with the USG60W?
Thx.
Hi @Wolfgang,
It supports at V4.39, however, it runs as forward compatible mode.
For full management, we are targeting to support it by end of November 2020.
As for 2nd question, the management AP service quantity is 2 by default, you can manage 2 AP on USG60W.
Thx.
But Wifi 6 will be enabled and work with V4.39 or not?
Hi @Wolfgang,
Yes, It does support Wifi 6 at V4.39.
Thx for the clarification.
Interesting is that in the release note PDF of v4.39 there is no comment that they are supported!
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
