GS1200-HP Firmware corrupted
Hi, my GS1200-8-HP switch blinks 3 times after power up and is not working
I connected a 3.3V USB Serial Adapter to the connectors on the PCB.
The output from the Terminal:
If i press "f" to upgrade i get this output:
-------------- GS608A Firmware -------------
------ Press "f" into firmware update ------
------- Press other key into boot up -------
== MAC Calculate Correct
== Boot Up After 3s
== Boot Up After 2s
== Boot Up After 1s
== Boot Up After 3s
== Upgrade GS608A App Now
== Erase Bank(0) ~ Bank(30)
CCCCCCCCCCCCCCCCCCCC
unfortunatelly i cannot send the firmware bin file with XMODEM.
is there still a possibility to restore the firmware?
Hi @dan53
Welcome to Zyxel community
Friendly remind that opening the chassis will break the warranty and it is not recommended to do it by yourself.
Based on your description, please use XMODEM with 1K as the picture below and try to upload firmware again
Best regards,
Zyxel_Derrick0 -
1k was the solution, thank you very much.-------------- GS608A Firmware ------------------- Press "f" into firmware update ------------- Press other key into boot up -------== MAC Calculate Correct== Boot Up After 3s== Boot Up After 2s== Upgrade GS608A App Now== Erase Bank(0) ~ Bank(30)----------------GS608A Start------------------I was able to flash the firmware, while flashing the system led flashes. Then it is off. I think it's more broken. The large heat sink gets relatively warm0
Hi @dan53
Since you have successfully uploaded the firmware to switch but it still can't be powered up.
I think the switch may be broken and please find the local reseller for repairing it
Best regards,
Zyxel_Derrick
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
