usg 40 with utm profile activated, does not upload 200 megabytes.
joanmega18
I have a zyxel usg 40 with utm profile activated, and an internet service of 200 megabytes but it does not upload 200 megabytes with the utm activated, but if I deactivate the utm profile if they go up to 200 megabytes.
The utm can hit your speed when active you might get more speed out of the USG40 with traffic statistics and unchecked.
https://businessforum.zyxel.com/discussion/4494/tip-for-getting-faster-throughput-on-usg-vpn-zywall
To go faster with UTM activate you need a faster model.
Hi @joanmega18,With UTM feature enabled, the traffic is thoroughly scanned by USG and the performance is affected.For better performance with UTM enabled, ATP100 and USG FLEX 100 would be suitable for your site.0
- 441 Beta Program
- 292 Service & License
