SSL Inspection and TSL 1.2
we´re going to implement the SSL inspection. But I see in the manual, that TSL1.2 and 1.1 is downgraded to TSL1.0. Is this still the case? Is the downgrade only for incoming data or for incoming and outgoing data?
The problem is, that a lot of relevant websites and services are using TSL1.2. These site´s won´t work when downgrading to TSL 1.0. If this is the case, we can´t use the SSL insprector.
Hi @Michael_I,
SSL Inspection supports SSLv3, TLS1.0, TLS1.1, and TLS1.2 if you want encrypted traffic.
Could you share the screen shot or the download link of the manual with us?
Here is a screenshot.The Filename of the download was atp200_V4-55_ED1.pdfSo, there is no downgrading?
Hi @Michael_I,
The information in the user guide is out of date.
We will update the description in the next version of user guide.
Thanks for your notification.
- 441 Beta Program
- 292 Service & License
