USG60W and WAX AP Series (Wifi 6)
Skylink
Skylink Posts: 32  Freshman Member
First Comment Friend Collector Seventh Anniversary
edited April 2021 in Security
Can USG60 manage new AP WAX Series (WiFi 6)?
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @Skylink,
    It does not support so far. We are targeting to support it by end of July 2020.
  • Wolfgang
    Wolfgang Posts: 39  Freshman Member
    1.) is the WAX510 already supported on the USG60W ?
    2.) Can i manage 2 WAX510 with the USG60W?
    Thx.
  • Zyxel_Cooldia
    Hi @Wolfgang,
    It supports at V4.39, however, it runs as forward compatible mode.
    For full management, we are targeting to support it by end of November 2020.
    As for 2nd question, the management AP service quantity is 2 by default, you can manage 2 AP on USG60W.
  • Wolfgang
    Thx.
    But Wifi 6 will be enabled and work with V4.39 or not?
  • Zyxel_Cooldia
    edited August 2020
    Hi @Wolfgang,
    Yes, It does support Wifi 6 at V4.39.
  • Wolfgang
    Thx for the clarification.
    Interesting is that in the release note PDF of v4.39 there is no comment that they are supported!
