Feature request {Exclude IP from DHCP Pool)
chandan
chandan Posts: 72 image  Ally Member
edited April 2021 in Security
Hello all,
As the discussion title says, Need a feature like excluding an IP from a DHCP pool range.
Please consider.
Thank you
    settings > network > IP/MAC binding > Exempt list tab
  • chandan
    It should be available in the Settings - Network - Ethernet and then inside the desired name at the DHCP pool server
  • Nigelo
    Nigelo Posts: 12 image  Freshman Member
    PeterUK is correct and with the greatest respect Chandan, the exemptions to IP/MAC bindings are exactly where they should be - as a subset of the IP/MAC bindings.
