Zysh daemon is busy
michaelJin
michaelJin Posts: 10 image  Freshman Member
edited April 2021 in Security
After upgrade to v4.39, I am getting 100% cpu from time to time, there are few alerts "Zysh daemon is busy"
and widget keep loading.
Any suggestion about it?
  • michaelJin
    The CPU is going up quickly if I click refresh widget quickly.
  • michaelJin
  • michaelJin
  • michaelJin
    Trying to set the widget refresh interval to 300, but somehow it is reset to default 0. What's the correct way to update it
  • michaelJin
    Username: admin
    Password:
    Router# debug system show cpu status
    CPU utilization: 99 % (system: 48 %, user: 21 %, irq: 0 %, softirq 30 %)
    CPU utilization (1 minute): 24 % (system: 9 %, user: 8 %, irq: 0 %, softirq 7 %)
    CPU utilization (5 minute): 56 % (system: 18 %, user: 21 %, irq: 0 %, softirq 17 %)
    Router#debug system ps
      PID  PPID COMMAND         USER     TT       PRI  NI %CPU %MEM STAT    VSZ   RSS    SZ    SZ  STARTED     ELAPSED     TIME COMMAND
     8559     1 capwap_srv      root     ?         19   0  0.0  0.2 Sl    87840  4404 76452 21960   Aug 24  4-21:21:12 00:04:25 /usr/local/bin/capwap/capwap_srv -p /var/run/capwap_srv.pid
     8521     1 tr069ta         root     ?         19   0  0.0  0.0 Sl    84876  1928 76216 21219   Aug 24  4-21:21:12 00:00:41 /usr/sbin/tr069ta
    10277     1 capwap_client   root     ?         19   0  0.1  0.2 Sl    78048  4080 68240 19512   Aug 24  4-21:20:39 00:07:30 /usr/local/bin/capwap_client -p /var/run/capwap_client.pid -m bc:99:11:b0:2e:90 -d
     3353     1 asd             root     ?         19   0  0.0  0.0 Ssl   66108  1920 43620 16527   Aug 24  4-21:21:55 00:01:41 /usr/sbin/asd
     8503     1 wacd            root     ?         19   0  0.0  0.0 Ssl   65676  1004 59728 16419   Aug 24  4-21:21:12 00:00:41 /usr/sbin/wacd
     1135     1 secu_reporter   root     ?         19   0  0.0  0.1 Ssl   59112  2396 52844 14778   Aug 24  4-21:22:06 00:00:09 /usr/sbin/secu_reporter
    12710     1 radiusd         root     ?         19   0  0.0  0.4 Ssl   57920  8152 45664 14480   Aug 24  4-21:19:58 00:00:00 /usr/sbin/radiusd -xxxd /var/zyxel/raddb/
     8748     1 bwmd            root     ?         19   0  0.0  0.0 Ssl   49784  1084 43356 12446   Aug 24  4-21:21:08 00:00:09 /usr/sbin/bwmd -d
     2745     1 zyssod          root     ?         19   0  0.0  0.0 Sl    49276  1344 43404 12319   Aug 24  4-21:22:01 00:05:35 /usr/sbin/zyssod
     2924     1 policyd         root     ?         19   0  0.0  0.0 Sl    49144  1336 43464 12286   Aug 24  4-21:21:59 00:00:00 /usr/sbin/policyd
     8504     1 l2isolationd    root     ?         19   0  0.0  0.0 Sl    48896  1420 43332 12224   Aug 24  4-21:21:12 00:00:11 /usr/sbin/l2isolationd
     2940     1 pro             root     ?         19   0  0.0  0.1 Sl    45056  2660 35832 11264   Aug 24  4-21:21:58 00:04:27 /usr/sbin/proactor1.2/pro
    10430     1 ModemManager    root     ?         19   0  0.0  0.2 Sl    42240  4784 27640 10560   Aug 24  4-21:20:37 00:00:00 /usr/sbin/ModemManager --debug
     3388     1 fbwifid         root     ?         19   0  0.0  0.0 Ssl   41124  1088 35216 10281   Aug 24  4-21:21:55 00:00:00 /usr/sbin/fbwifid
    10438     1 accountingd     root     ?         19   0  0.0  0.0 Ssl   40664   952 35144 10166   Aug 24  4-21:20:37 00:00:05 /usr/sbin/accountingd
     3417  3410 zyshd           root     ?         19   0  0.3  0.6 Dl    39576 12460 13648  9894   Aug 24  4-21:21:55 00:26:48 /bin/zyshd -k /bin/zysh -l /var/run/zyshd-init.lock
     3400     1 2FAd            root     ?         19   0  0.0  0.0 Sl    35196  1200 26952  8799   Aug 24  4-21:21:55 00:00:25 /usr/sbin/2FAd
     4525     1 contfltd        root     ?         19   0  0.0  0.1 Ssl   33360  3824 18788  8340   Aug 24  4-21:21:37 00:00:21 /usr/sbin/contfltd
    24901 24900 zysh            nobody   ?         19   0  0.0  0.1 S     32780  2588  1452  8195 11:16:30       00:50 00:00:00 /bin/zysh -x
    22495 22389 zysh            root     pts/1     19   0  0.0  0.1 Ss+   32776  2388  1448  8194 11:09:05       08:15 00:00:00 /bin/zysh -p 100
    24904 24903 zysh            nobody   ?         19   0  0.0  0.0 S     32584  1332  1256  8146 11:16:30       00:50 00:00:00 /bin/zysh -x
    24957 24956 zysh            nobody   ?         19   0  0.0  0.0 S     32584  1332  1256  8146 11:16:53       00:27 00:00:00 /bin/zysh -x
    25040 25039 zysh            nobody   ?         19   0  0.1  0.0 S     32584  1332  1256  8146 11:17:11       00:09 00:00:00 /bin/zysh -x
    24907 24906 zysh            root     ?         19   0  0.0  0.0 S     32584  1308  1256  8146 11:16:37       00:43 00:00:00 zysh -p 110 -e show cpu status|xml
     8498     1 fauthd          root     ?         19   0  0.0  0.0 Ssl   31484   700 25916  7871   Aug 24  4-21:21:12 00:00:00 /usr/sbin/fauthd
     2925     1 firewalld       root     ?         19   0  0.0  0.0 Sl    30156   836 26940  7539   Aug 24  4-21:21:59 00:00:00 /usr/sbin/firewalld
     8556     1 redis-server    root     ?         19   0  0.2  0.1 Sl    29680  2172 25812  7420   Aug 24  4-21:21:12 00:18:01 /usr/local/bin/redis-server 127.0.0.1:6379
    10301     1 info_transfer   root     ?         19   0  0.0  0.0 Sl    29124  1044 24904  7281   Aug 24  4-21:20:38 00:00:11 /usr/sbin/info_transfer
     3180     1 fqdnobjectd     root     ?         19   0  0.0  0.0 Ssl   28300   656 24904  7075   Aug 24  4-21:21:57 00:00:13 /usr/sbin/fqdnobjectd
     2837     1 sched           root     ?         19   0  0.0  0.0 Ssl   27680   524 25900  6920   Aug 24  4-21:21:59 00:00:00 /usr/sbin/sched
    10439     1 user_logout     root     ?         19   0  0.0  0.0 Sl    27312   720 24892  6828   Aug 24  4-21:20:37 00:00:08 /usr/sbin/user_logout
     1137     1 uamd            root     ?          0  19  0.0  0.0 SNsl  26476  1808 18060  6619   Aug 24  4-21:22:06 00:01:18 /usr/sbin/uamd
     2793     1 rumd            root     ?         19   0  0.0  0.0 Ssl   25992  1416 17808  6498   Aug 24  4-21:22:00 00:00:00 /usr/sbin/rumd
    10572     1 ttyd            root     ?         19   0  0.3  0.1 Sl    24188  2676 17860  6047   Aug 24  4-21:20:35 00:21:44 /usr/sbin/ttyd -p 11080 web-console-login
     8505     1 radio_scheduled root     ?         19   0  0.0  0.0 Sl    23224   840 17724  5806   Aug 24  4-21:21:12 00:00:00 /usr/sbin/radio_scheduled
     2926     1 sessionlimitd   root     ?         19   0  0.0  0.0 Sl    20840   724 17724  5210   Aug 24  4-21:21:59 00:00:00 /usr/sbin/sessionlimitd
     3964     1 raddb_wtp_conf  root     ?         19   0  0.0  0.0 Sl    20208   832 17788  5052   Aug 24  4-21:21:42 00:00:00 /usr/sbin/raddb_wtp_conf
     8614     1 wireless_hal    root     ?         19   0  0.0  0.0 Sl    19644   736 17712  4911   Aug 24  4-21:21:11 00:00:47 /usr/local/bin/wireless_hal
    10451     1 autohealing     root     ?         19   0  0.0  0.0 Ss    18560   668   328  4640   Aug 24  4-21:20:37 00:00:00 /usr/sbin/autohealing
    18306  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18472  4896  2216  4618   Aug 28  1-01:15:25 00:00:02 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    20400  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18380  4908  2124  4595   Aug 28  1-01:09:35 00:00:01 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19844  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18368  4816  2112  4592 11:01:07       16:13 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
     7119  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18368  4744  2112  4592 10:22:57       54:23 00:00:01 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19814  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18352  4780  2096  4588 11:00:57       16:23 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    20364  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18352  4720  2096  4588   Aug 28  1-01:09:42 00:00:02 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19880  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18348  4696  2092  4587 11:01:14       16:06 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    20371  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18344  4728  2088  4586   Aug 28  1-01:09:40 00:00:02 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    21580  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18328  4724  2072  4582   Aug 28  1-01:06:27 00:00:01 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19881  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4704  1980  4559 11:01:14       16:06 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19836  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4696  1980  4559 11:01:03       16:17 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19921  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4676  1980  4559 11:01:26       15:54 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19876  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4652  1980  4559 11:01:13       16:07 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19837  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4632  1980  4559 11:01:03       16:17 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19820  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4628  1980  4559 11:00:58       16:22 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19832  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4624  1980  4559 11:01:02       16:18 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19821  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4612  1980  4559 11:00:58       16:22 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19828  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4612  1980  4559 11:01:00       16:20 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19916  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4612  1980  4559 11:01:24       15:56 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
    19938  9916 httpd           nobody   ?         19   0  0.0  0.2 S     18236  4608  1980  4559 11:01:28       15:52 00:00:00 /usr/local/apache/bin/httpd -f /usr/local/zyxel-gui/httpd.conf -k graceful -DSSL
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,461 image  Zyxel Employee
    Hi @michaelJin,
    We need to check why zysh daemon is busy on your device remotely.
    I'll contact you in private message for remote access information.
