Firmware update appears to be stuck
I apologise if this is the wrong forum but looking for help. I purchased the USG60 today with firmware 4.33 on it. I am no trading to upgrade to 4.39 firmware however it has been going for over an hour. Is this normal? How long should this take or any advice? Thanks in advance.
Hi @Off,
The complete firmware update may take up to 5 minutes with default configuration file.
If the device didn't upgrade to 4.39 successfully, reboot USG60 manually and check what version is in the Running partition.
If the running partition is still 4.33, try to upload firmware 4.39 to the Standby partition.
i can report, the uplod to USG without reboot after upload is running, but @Zyxel_Emily it's different to other vendors, cause the other refresh the upload progress bar and tell you "upload successfull to solt x". At ZyXEL the progress bar is running until you reconnect to USG to check the upload is still placed in the slot on USGbefore you upgrade, please connect also to COM Port at the USG and configure Putty for Serial connection to see the upgrade process in the Serail screen
that can help you to locate an issue or the rollback message in the serial window.
In my case it takes 10-12 minutes for an firmware upgrade, cause i've arround 189 rules and a lot of address/service elements configuredregards and good luckChristian0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
