How to setup VPN to connect from ipad
DK22
DK22 Posts: 2 image  Freshman Member
edited April 2021 in Security
Dear All,
Recently I got USG20-VPN firewall and want to understand step by step VPN configuration so users can connect to network via remote location using their iPads. I also want remote users to access network resources once they are connected. Can someone please guide me in the right documentation or videos or explain here the steps to follow.
I would highly appreciate a response from some expert.
Thank you in advance
Regards,
DK
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,499 image  Zyxel Employee
    Hi @DK22,
    You can follow the steps in CONFIGURATION > Quick Setup > VPN Setup > VPN Settings for L2TP VPN Settings to configure L2TP VPN on USG20-VPN.
    Note: The IP Address Pool for L2TP VPN cannot conflict with WAN/LAN/DMZ or any existing subnets even if they are not in use.
    Then go to Object > User/Group > User to add L2TP users.
    Configuration on iPhone/iPad
    https://businessforum.zyxel.com/discussion/comment/10888#Comment_10888
    If USG20-VPN is placed behind a NAT router, here is the guide for your reference.
    https://businessforum.zyxel.com/discussion/675/how-do-i-configure-the-zywall-for-a-l2tp-server-behind-nat
  • DK22
    I tried the advised steps but it is not working. My wan internal interface IP is 192.168.1.115.
    Firewall IP is 192.168.10.1 and DHCP is assigning range from 192.168.10.33
    I want users to connect via VPN and use the server which is using 192.168.10.33 IP.
    Can you please explain me what I have to do to make it work. what IP I have to give in range Pool so users can connect and access server.
    I would appreciate a response soon.
    regards,
    DK
  • Zyxel_Emily
    Hi @DK22,
    Is it the topology in your network?
    What is the WAN IP of the router?
    About IP Address Pool for L2TP VPN users, just set a subnet which doesn't conflict with other existing subnet.
    Since 192.168.10.0/24 and 192.168.1.0/24 are already used, assign another subnet for L2TP VPN pool. For example: 192.168.60.0/24.
