USB Storage not in use
Hello zyxel team,
What is the minimum & maximum USB storage can be used with Zyxel USG110?
In my case, I have tried to use 8 GB pen-drive with FAT-32 format. But it did not work.
Please see the error below.
And why a 8 GB flash drive is showing as 2048.0 GB (2TB).
However, a 16 GB pen-drive is working properly.
Note: I have tried 3 other pen-drive of same capacity i.e. 8 GB from different manufacturer and the error is same as above. I think this is a bug in the firmware and needs to be rectified.
Best Answers
Hi @chandanps18,If the file system of USB flash is formatted with FAT32 but it still shows "unknown" on USG110, keep USB flash connected and give me the web GUI access of USG110 in private message.We'll login and use web console to check the symptom.6
Hi @chandanps18,
The partition type “0xEE”of your USB storage is not supported.
We support partition type of FAT32 is “0x0B” or “0x0C” only.
We suggest you find another USB storage with the supported partition type to use on USG110.
The following partition types are not supported by USG.
0xEE: GPT protective MBR
0xEF: EFI system partition
The file system shows "unknown". Here are some useful information found in knowledge base.
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015879&lang=EN
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=012385&lang=EN
Hi @lalaland
Thanks for your reply.
The file system is formatted with FAT32 only and for sure I am not committing such silly mistake before posting it into the public forum.
These flash-drives (all 8GB pendrives) are working properly in PC without any issue.
But it is not working with USG device.
Anyway, I will try with Minitool Partition software and let you know after..0 -
No the result is still same
Router# show usb-storageUSBStorage Configuration:Activation: enableCriterion Number: 100Criterion Unit: megabyteUSB Storage Status:Device description: SanDisk Cruzer BladeUsage: 2048.0GBFilesystem: unknownSpeed: USB 2.0 480MbpsStatus: UnusedDetail: OutOfSpaceFacility:Format:Router#
As I told earlier the issue is having only with 8GB pen drive (3 no of 8GB pendrive shows the same information posted above i.e. 2048GB, OutOfSpace and all), so needs to check again from the developer.0 -
Hi @chandanps18,
Hello @Zyxel_Emily
Thanks for the info.
Yes, the disks were initialized as GPT and the file-system was formatted as FAT32.
After successfully converting it to MBR and formatting the file-system to FAT32, the USB storage is accessible to the firewall.
Note: Please modify the firewall guide (available in the website) and make a note of this i.e. the USB storage device should be initialized as MBR but not as GPT.
Regards0 -
Use Rufus to format the drive. Set it to non bootable. Rufus can be found on Portableapps The other settings are locked. Click start. Only method that has worked for me.0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
