Not able to log in to the VPN2S after Firmware upgrade
Ok,
with this firmware is perfect.
Now the firewall is great.
Thanks0 -
No more problems0
I got the easy and correct answer who was to set https:\ before the router adress. Thanks for a quick and correct answer from your support forum.0
Hi Emily,Zyxel_Emily said:Hi @MPOster,
We have fixed the issue in the latest firmware.
The firmware is sent to you in private message.
Fix: HTTP Access to WEB-GUI
Please send me a firmware link for this issue.
Thanks0 -
Hi @bankkelvin,The firmware is sent to you in private message.0
HI,
Please send me firmware link as facing same issue.
Thanks0 -
Hi @CA_Anand_Joshi,The firmware is sent to you in private message.0
Same Problem! What the f....!0
Hi @stuwich,VPN2S firmware is available in "Firmware Release".0
wow... that will help others too!Zyxel_Emily said:Hi @stuwich,VPN2S firmware is available in "Firmware Release".
After many reboots - was able to update. No OK again.
Thanks0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
