How can I release IPs from the DHCP pool on NXC5200?
Running_MAN
Hi, I use NXC5200 as my DHCP server, but the DHCP pool is full now. The new clients cannot get IP but there have too many redundant users, how can I release them???
Hi @Running_MAN,
There is no command or function to clear the DHCP pool when the pool is full.
Our suggestion is shorten the lease time and re-open the DHCP server or reboot the NXC.
Re-opening the DHCP will interrupt the service for a while, but all the IPs will be released from the DHCP server.
1. Shorten the lease time.
2. After finish the setting, reboot the NXC.
or if you don't want to reboot the NXC, you can do as below
2. After finish the setting, disable the radio.
3. Disable the DHCP server.
Remember the settings of the DHCP server and set DHCP to "none". Press "Apply".
4. Set DHCP to "DHCP server" again and enter the configuration.
5. Enable the radio.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
