USG 1000 block by mac address
The USG can't block by MAC so you have two options:
get a managed switch and ACL by MAC.
use the IP/MAC Binding in the USG to give the MAC a fixed IP you can block in the firewall.
Peter,I have a managed switch..so I'll investigate that option.Regarding the ip/mac binding, I was playing with that on a local USG 1000 in my office, and locked myself out of the router. Luckily I had backed up my startup-config and recovered nicely..However I couldn't figure out how to block in the firewall.Should I create an address using Objects, then use that object name in the firewall?Thanks again for your input.0
Yes but you need the ip/mac binding to make that MAC be fixed to a IP
Doing it by managed switch would stop the MAC getting a IP but if it changes its MAC it be allowed again even if not they can set a fixed IP and have access to the subnet.
do you know if the device on your network is connected to a switch port?0
- 441 Beta Program
- 293 Service & License
