USG 1000 block by mac address
mm_bret
mm_bret Posts: 67  Ally Member
edited April 2021 in Security
I have a pc or device on my network which I don't recognize.
I'm not able to go to the physical location.
How can I block this device from connecting to my lan?
We have dhcp setup on the router.
All ideas appreciated.
Bret
    PeterUK Posts: 3,892  Guru Member
    The USG can't block by MAC so you have two options:
    1. get a managed switch and ACL by MAC.
    2. use the IP/MAC Binding in the USG to give the MAC a fixed IP you can block in the firewall.
  • mm_bret
    Peter,
    I have a managed switch..so I'll investigate that option.
    Regarding the ip/mac binding, I was playing with that on a local USG 1000 in my office, and locked myself out of the router. Luckily I had backed up my startup-config and recovered nicely..
    However I couldn't figure out how to block in the firewall.
    Should I create an address using Objects, then use that object name in the firewall?
    Thanks again for your input.
    edited September 2020
    Yes but you need the ip/mac binding to make that MAC be fixed to a IP
    Doing it by managed switch would stop the MAC getting a IP but if it changes its MAC it be allowed again even if not they can set a fixed IP and have access to the subnet.
    do you know if the device on your network is connected to a switch port?
