GS1900-24 Load Balancing Possible?
I have a GS1900-24 switch and have just purchased a 4G Router in addition to my DSL connection.
I have read on the internet about load balancing switches making it possible to combine 2 internet connections, does this switch do that or do I need something else?
Thanks in advance!
Thanks in advance!
Hi @mbc0
GS1900 series supports link aggregation which is grouping physical ports into one logical link.
I think this is what you are looking for
For further information, you can check user's guide Chapter 22 Link Aggregation
https://www.zyxel.com/support/download_landing/product/gs1900_series_23.shtml?c=gb&l=en&pid=20130521174809&tab=User_s_Guide&pname=GS1900 Series
Best regards,
Zyxel_Derrick0 -
Thank you for your reply but from what I understand Link aggregation is different to wan aggregation?0 -
Hi
Yes, they are different.
Our switch does not have WAN interface and therefore does not support WAN aggregation
Best regards,
Zyxel_Derrick0
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
