USG40 - DDNS - Password can't accept "?"
I'm trying to configure ddns profile but in my password I have char "?" and I can't use it in password field!!
I'm little surprise... it's a normal char/symbol.
I can't change the ddns password, I have many host registered.... it is a big issue for me.
Any solution?
Many Thanks
Daniele
Best Answers
Hi @Gaffu85,
The symbol "?" is a reserved symbol in the command line of terminal command environment.
The function of "?" is help command to list the available commands.
Hence, it is not allowed to be configured in the password.
We can build a firmware which supports the symbol ? in the password of DDNS for you to run the test.
Just let me know if you’d like to try the firmware in the private message.
5 -
Hi @Gaffu85,The firmware is sent to you in private message.1
Hi @Gaffu85,
5 -
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
