USG20W-VPN - No WLAN tab in Interface Menu
SistemistaDaRidere
SistemistaDaRidere Posts: 12 image  Freshman Member
edited April 2021 in Security
hello
I have this weird problem
first i configured ssid in EZMODE, then i deactivated it and started to configure it from expert mode.
Everything is correctly set up but no WLAN tab is showing in interfaces menu
Don't know what else i can try
  • Zyxel_Emily
    Hi @SistemistaDaRidere,
    We don't allow users to change Easy Mode configurations in Expert Mode.
    If you'd like to configure advanced settings in radio profile or SSID, just start directly with Expert Mode to configure advanced settings in CONFIGURATION > Object > AP Profile.
  • Zyxel_Emily
