What does this mean??
The screenshot is clear.
Please open the image in a new tab Or else save the iamge into your computer and try opening from your PC.
Regards0 -
My guess would be its to do with log & report > Email Daily Report ?
No, I have not activated email daily log...0
Hi @chandan,
The error message means there is some problem sending the mail using the Mail Server.
The setting is not only for email daily report but also syslog and 2FA authentication.
You can check if you configured Mail Server correctly in Configuration > System > Notification.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
