WAC6552D-S reset configuration to default
Have a WAC6552D-S which have been managed by the management feature in VPN100. I don't want the VPN100 to manage it anymore, so I have removed it from the management page. It's configured with a static IP address, and I can find it with the ZON utility. The headache is, that I think it has been configured with a password that I don't know. So, doing a reset configuration to default is not possible that way.
I guess that the WAC6552D-S is not equipped with a reset button, so what is my options to do a configuration reset?
Any help appreciated!
Best regards Ole
Best regards Ole
Hi @OWB
The AP password will be the same as the controller after managed by the controller. Please try to use the password of VPN100 to login the WAC6552D-S. Since there is no reset button on the WAC6550D-S, we have to reset the AP via SSH or ZON.
Reset from SSH
Router> apply /conf/system-default.conf
Hope it helps.
Joslyn
5
Hi @OWB
Reset from SSH
Hope it helps.
Joslyn
5 -
Hi Joslyn,
Thanks a lot, I manage to perform a configuration reset from the ZON utility, by using the VPN100 password.
It annoys me a bit that I did not try that before I asked for help here. :-(
Thanks.
Best regards Ole.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
