USG20W-VPN Configure wlan in expertmode?
Andreas
Andreas Posts: 3  Freshman Member
edited April 2021 in Security
Hello
Is it me or is it not possible to create wlan in expert mode?  Under the configuration- Wireless it only have AP Management and DCS and there is no way to configure the wlan?
//Andreas
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    Hello Andreas,
    Please follow the below way to configure the local(Internal) AP.
    Go to AP profile>SSID> configure the pre-shared key
    Go to SSID List to configure SSID's profile name and SSID.
    On the Radio, you can create the profile for 5G or 2.4G
    Move to Wireless>AP management, you can select which frequency you want to connect and choose SSID profile.
    Note: On the USG20W-VPN, you only can select one frequency at one time.
    Charlie
  • Andreas
    Thanks, i totally missed the AP Profile under objects.
  • Darling
    Darling Posts: 1  Freshman Member
    Charlie
    Thank you for the information about the Zywall wireless setup. It was helpful I was able to configure and connect. Awesome!!
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,520  Zyxel Employee
    Hi @Darling ,
    Welcome to Zyxel community. Just feel free to ask question here.😎
  • S0krates
    S0krates Posts: 1  Freshman Member
    I have a USG40W. Is it me or is it not possible to create 5GHz wlan in expert mode?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,418  Zyxel Employee
    Hi @S0krates,
    The build-in WiFi (Local AP) on USG40W only support 2.4GHz.
    For managed AP which supports 5GHz, follow the guide below to configure 5GHz radio profile and Radio 2 setting.
