What does this mean??
chandan
chandan Posts: 72 image  Ally Member
edited April 2021 in Security
Hello Zyxel Team,
I found this from the system log.
Whether this is a error or what I am unable to get it.
The system is running of the firmware version:
V4.39(AAPH.0)ITS-WK32-r95434
Please check
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,452 image  Guru Member
    The screen shot looks vague.
    Could you post the error message again?
  • chandan
    The screenshot is clear.
    Please open the image in a new tab Or else save the iamge into your computer and try opening from your PC.
    Regards
    PeterUK Posts: 4,160 image  Guru Member
    My guess would be its to do with log & report > Email Daily Report ?
  • chandan
    No, I have not activated email daily log...
  • Zyxel_Emily
    Hi @chandan,
    The error message means there is some problem sending the mail using the Mail Server.
    The setting is not only for email daily report but also syslog and 2FA authentication.
    You can check if you configured Mail Server correctly in Configuration > System > Notification.
