Creating several VPNs with different public IP addresses
Hi @Kv3,
If you don't create virtual interfaces for other public IP addresses, you can also add NAT rule to bind the alternative IP on the interface.
Here are examples for your reference.
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=016375&lang=EN
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=016415&lang=EN
In Ethernet > wan, only 10.214.48.58 is configured.
In NAT setting, add a rule with the external IP using alternative IP 10.214.48.67.
Then you can create the VPN gateway by entering the alternative IP 10.214.48.67.
Hi, Emily
when I configure NAT, what IP address should I set in "User-Defined Internal IP" ?
Hi @Kv3,
The most important step is to configure the alternative IP address 12.34.56.212 - 12.34.56.215 in "External IP", so you can configure an inexistent internal IP address.
Actually, you can add up to 4 virtual interfaces for wan interface.
It would be simpler to create 4 virtual interfaces with the IP address 12.34.56.212 - 12.34.56.215 and use these wan virtual interfaces to build VPN tunnels.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
