Wrong time after reeboot with ATP 200
What happens if you enable daylight savings?
6
6 -
Hi @Michael_I,
After reboot, our ATP200 with firmware 4.55(ABFW.0) still gets the correct time zone UTC+8.
In log, select the type "System" and check NTP update result.
If the time zone is still incorrect, send the remote access of ATP200 to me in private message.
Thanks, I´t was the daylight saving option.
- 211 Nebula Ideas
- 544 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 465 News and Release
