Port 443 already used and SSL VPN
Sorry for my english, i'm french.
My client has a device that uses the port 443, it's for postage service.
This device has been in place for a long time. I created a nat rule so that the packets from the wan are redirected to this device.
Ip adress is 192.168.3.51
I need to set up an SSL VPN. It uses port 443.
When the nat rule is active, i can't use the SSL VPN because the nat rule is priority.
Do you have a solution ?
Hi @Yannick,You can follow the configuration guide in this discussion to change the service port from 443 to another port.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
