Zyxel WAC6553D-E
Bom dia tudo tranquilo? Estou com um zyxel WAC6553D-E que retirei da caixa agora a pouco comprado novo junto com outros do mesmo modelo, porém esse eu tenho resposta de ping no ip padrão 192.168.1.2, acesso ele via SSH e via terminal, ja resetei e não consigo acessar ele pelo navegador para configurar, só aparece a mensagem ERR_CONNECTION_REFUSED. Ja testei em outros computadores e ate mesmo com outros navegadores e continua do mesmo jeito sem acesso para fazer a configuração.
Hi @Leoni137 ,
Since we only support in English or Chinese, after I read from google translate, the issue should be that the AP can be SSH, but can't be accessed via the web GUI page with error message. If there's any misunderstanding, please kindly let me know.
May I know is there a NXC controller in your topology? If yes, when the AP was managed by the NXC controller, the web page is not able to access.
If not, please try to use below commands to reset the AP to default via SSH.
Router> apply /conf/system-default.conf
Or, if you have done the reset but still not workable, please enable the HTTP/HTTPS server again via below commands.
Router> configure terminal
Router(config)# ip http server
Router(config)# ip http secure-serverRouter(config)# writeRouter(config)# exit
Hope it's helpful.0
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
