Delete VPN setting in EZmode
Hi @DannyC,
The settings configured in Easy Mode cannot be modified in Expert Mode. It is to avoid settings conflict between different modes.
To delete VPN settings which are created in Easy Mode, switch to Expert Mode and delete the EZMODE_VPN rule.
If you'd like to configure advanced settings in VPN Gateway and VPN Connection, just start directly with Expert Mode to configure in CONFIGURATION > VPN.
Hi Emily,
I'm not able to get to the web configuration page anymore. However, I can SSH to the device locally. Is there a command in SSH setting to delete the EZMode VPN rule?0 -
Hi @DannyC,Router> configure terminalRouter(config)# no ezmode config-vpnRouter(config)# no crypto map EZMODE_VPN_STATICRouter(config)# no isakmp policy EZMODE_VPN_STATICRouter(config)# write0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
