Content filter 4.39
IT_Field_Support
We have noticed a problem on a router USG40w after 4.39 upgrade. Users told us that website that were ok before the upgrade are now blocked.
As you can see, we tried to test it with cli but we have an error.
Also, the category in the CF are all messed up.
What can we do ?
Thanks,
Davy
You can follow the instruction in this discussion to enter Ctrl+F5 to hard refresh the browser.0
Hi @Zyxel_EmilyThanks for the reply, I got it working with your solution.What about the CF not responding ?Thanks,Davy
To find out the root cause of the error of query, send the remote access of the web GUI in private message.
We will use web console to check the symptom.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
