Ipsec VPN client only ping from one place
JurgenDs21
i had a particular problem.
I set an Ipsec vpn on an USG 20 at a customer site, then i configurate the client on a laptop in my office.
The tunnel go up and i ping the server easily. I see network folders and i can use all programs.
When i go home with the laptop i try to connect again.
Tunnel go up but....i can't ping server.
Why?
I need the server to be seen everywhere i connect the tunnel.
THX
Why?
THX
It is probably that the IP address of internal servers and the home network have the same subnet.What are the IP address and subnet mask of internal servers? What are the IP address of the laptop obtained in the home network?Try to use the command "netstat -r" on your laptop before and after vpn tunnel is dialed up from home.0
- 588 USG FLEX H Series
- 477 News and Release
