Firmware Upgrade - FQDN question
kyssling
kyssling Posts: 107 image  Ally Member
First Comment First Answer Friend Collector Sixth Anniversary
edited April 2021 in Security
Hello, please if i have output with command
show running-config |match "fqdn"
Router> show running-config |match "fqdn"
 local-id type fqdn AAA.HIDE.cz
 local-id type fqdn BBB.HIDE.cz
logging usb-storage category fqdn-object level all
logging system-log category fqdn-object level normal
logging syslog 1 category fqdn-object disable
(AAA.HIDE.cz is example)
Is this OK and I can upgrade or not ?
Very thanks for answer
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @kyssling
    You can update firmware without suffering this issue, since  you did not create the FQDN object on Address filed.
