Bugs for VPN2S and ideas
VPN2S with V1.20(ABLN.1)
For the default WAN1 none of the DHCP client options stick and would it be possible to make the DHCP look like say a USG40 or win 10 Discover/request please?
Setting up a PPTP VPN your meant to enable in device service for the PPTP for a given WAN but it works without needing to do so. so I found that you can either allow all to work by enable in device service or firewall in PPTP.
Android 7.0 phone connecting to the PPTP VPN over 4G disconnects when idle for some minutes.
And no way to firewall connections from a PPTP/L2TP VPN ? Would it be possible to give this a zone to firewall please?
Set MAC address on default WAN1 arp the default MAC and set MAC.
Hi @PeterUK,
Thanks for your confirmation in the private message that the bug "Set MAC address on default WAN1 sends default DHCP discover MAC and set MAC on WAN1" no longer exists after VPN2S is upgraded to 1.20(ABLN.2).
1.20(ABLN.2) bug
Bug- Invalid time server IP address: Other
When you select other for time server and put in ntp.virginmedia.com it says invaild but it worked fine in V1.20(ABLN.1)
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
