Internet slow
Do you have the newest firmware?
Do you use any of the UTM options?
Maybe try the following firmware found here
https://businessforum.zyxel.com/discussion/4751/weekly-firmware-support-version-lab-version#latest
I upgrade the firmware this morning nowI am trying to test it. i use utm option like content filter.0
@LeviPonti
If the content Filter enabled, every packet will be scanned by UTM function may consume the resource and affect the throughput result.
You can try to disable the Content Filter to see if the performance become better.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
