PPTP VPN keep alive timer set to only works after a reboot
@PeterUK
The case seems the similar with another thread you created, therefore we could discuss it on below link:
https://businessforum.zyxel.com/discussion/5029/win-10-android-7-0-phone-connecting-to-the-pptp-vpn-over-4g-disconnects-when-idle-for-some-minutes#latest
Charlie0 -
Its not similar one is about keep alive timer the other is how long the VPN stays connected.0
@PeterUK
After PPTP VPN established, if doing nothing and idle for some time past the VPN connection disconnects even you have done the reboot action. It's normal behavior since the unit of keep alive timer is Seconds.
Charlie0
- 588 USG FLEX H Series
- 477 News and Release
