ATP200 Wan/Lan Bridge Mode with VLANs
MartyWalter
MartyWalter Posts: 32 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Security
We are installing an ATP200 between a customers VPN100 and their network (as suggested by ZyXEL sales).  The VPN100 (in SDWAN mode) has the native VLAN as well as two VLANs for voice/guest traffic.
We are struggling with passing the Voice/Guest vlans across the bridged ATP200.
If anyone has a suggestions for the proper settings in the ATP200, it would be greatly appreciated.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @MartyWalter
    Regarding to your description,
    the configuration of Vlan on VPN100 need to configure untag, and bridge Wan and Lan interface on ATP200 then check it again.
  • MartyWalter
    This is exactly how we have the ATP200 programmed.  It does not pass vlan7 or vlan10 from the VPN100 to the network.
    PeterUK Posts: 4,429 image  Guru Member
    edited October 2020
    Maybe you need to make VLAN 7 and 10 on the ATP200 base port LAN1 then add them in the Bridge?
  • MartyWalter
    I tried that, the issue was that then the vlan7 dhcp started serving up addresses on the native vlan.
  • Zyxel_Charlie
    @MartyWalter
    Regarding to this case,
    The ATP200 doesn't support VLAN trunk on bridge mode. It supports mainly un-tagged traffic.
