I cant log on ssl vpn all of a sudden
Hello everytime I try to log on from my new house to my usg 310 with sslvpn that I have done many times I am told that cant connect my ip address is on the lockout list . I see people say to use cli but when I open up cli from the gui on usg it doesnt do anything there is no place to type anything. Can someone please help me with this?
Thank you
@cyruss612
Do you mean the web console cannot be opened? Can you use the Incognito window then check it again.
Also, you can use console cable connect with USG310 and type the CLI on tera term or Putty application.
Hello I am attatching a screen shot . On my zyxel usg310 there is a cli option on top when I click on it i get this below.
The problem is I cant connect through the ssl secure extender zywall software .
@cyruss612
You should click the Web console icon on the top of GUI not CLI icon to type command.
You can reference from the link regarding to configuration of SSL VPN
https://businessforum.zyxel.com/discussion/5053/how-to-establish-ssl-vpn-tunnel-from-windows-pc/p1?new=1
Thank you so much for this information.
- 234 Nebula Ideas
- 6.7K Security
- 695 USG FLEX H Series
- 366 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 510 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 114 Security Highlight
