NXC 2500 " Wrong CLI command" after Login...
Hi @Zaddel
Before you login the NXC's GUI, please note that1. Turn on Javascript and Cookie setting in your web browser.
2. Turn off Popup Window Blocking in your web browser.
3. Turn on Java Runtime Environment (JRE) in your web browser.
Test the browser with those version.
The NXC Web Configuration allows easy management using an Internet browser. Browsers supported are:•Firefox 36.0.1 or later•Chrome 41.0 or later•IE 10 or later
Please confirm the firmware version is using the latest 5.10 and check the pop up message if has the error number or other message? Is any possible share the screenshot for us? Thanks.
Kathy0 -
Hey Kathy,the issues is still happen with each kind of browsers and settings. Firmware is 5.0...
Hi @Zaddel
I suggest you upgrade firmware to 5.10 by FTP.
There is FAQ teach you upgrade FW by FTP.
https://businessforum.zyxel.com/discussion/649/how-to-upgrade-firmware-to-controller-access-point-by-ftp#latest
Kathy0 -
Ahoi Kathy,
upgrading the firmware solved the Problem, cheers
- 603 USG FLEX H Series
- 481 News and Release
