win 10/Android 7.0 phone connecting to the PPTP VPN over 4G disconnects when idle for some minutes.
So I setup a PPTP VPN server on the VPN2S I connect to it by my phone that got Android 7.0 when doing nothing and idle for some time past the VPN connection disconnects and does not stay connected.
also happens with win 10 over 4G too
@PeterUK
It's normal behavior that if there is none of traffic on PPTP tunnel, the tunnel will be disconnected in the seconds which you set on the Keep timer filed.
Otherwise, the tunnel can be alive for mins because after tunnel established, server and client will send negotiate packet in the tunnel in the beginning.
Charlie0 -
If the keep alive timer is set to 1 with a reboot to set it when no traffic being sent the keep alive timer sends a echo request back to the client from port 1723 every second this is to keep the connection alive but does not keep the GRE tunnel alive.
So the keep alive timer is to stop the tunnel from closing but fails to do so because it does not keep the GRE tunnel alive only the PPTP port by TCP.
If keep alive timer is set to 1 second it takes minutes before the tunnel disconnects not the tunnel will be disconnected in the seconds which you set on the Keep timer filed.
If you can make the keep alive timer send a ping to the client by GRE this will solve the disconnection problem.
@PeterUK
Can you screenshot the configuration on PPTP page? I would like to check it on my lab.0 -
Note that I made a firewall rule for PPTP from WAN to router which seems to auto allow GRE also the keep alive timer set to 1 only works after a reboot.
@PeterUK
Is it your purpose to let the PPTP tunnel stay connected even PPTP client idle for a while?
Zyxel_Charlie said:@PeterUK
Yes and I thought the keep alive timer was to do just that, the only other way to keep the tunnel open is for the client to send a ping.
@PeterUK
We dont have any plan in certain enhancement. However, to have further evaluation, I would like to move this case to Ideas.0 -
Dear Zyxel team, could you update the keep Alive Timer feature in Nebula cloud, I need this feature, thanks
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 501 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
