SSL VPN - no connection via Remote Desktop
we can connect inside the VPN via Remote Desktop when we use a connection from a fixed IP computer, but as soon as we connect via a laptop (with a dynamic IP), the VPN gets established but the Remote Desktop connection is not successful. Error message: "Either remote desktop computer not available ...". We use a SSL connection - do you recommend to use an IPSec connection instead? Thank you very much for your help!
@blk_care
The remote desktop is working successfully in SSL VPN tunnel with 4.39 wk38 from my lab.
You may upgrade to this firmware version first then check it again
https://businessforum.zyxel.com/discussion/4751/weekly-firmware-support-version-lab-version#latest
My Lab
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 495 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 456 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
