NXC 2500 " Wrong CLI command" after Login...
Zaddel
Posts: 3 Freshman Member
After Login on the NXC 2500, " Wrong CLI command" pops up on every point of the menu. a restart has no effekt.... any ideas ?
Hi @Zaddel
Before you login the NXC's GUI, please note that1. Turn on Javascript and Cookie setting in your web browser.
2. Turn off Popup Window Blocking in your web browser.
3. Turn on Java Runtime Environment (JRE) in your web browser.
Test the browser with those version.
The NXC Web Configuration allows easy management using an Internet browser. Browsers supported are:•Firefox 36.0.1 or later•Chrome 41.0 or later•IE 10 or later
Please confirm the firmware version is using the latest 5.10 and check the pop up message if has the error number or other message? Is any possible share the screenshot for us? Thanks.
Kathy0 -
Hey Kathy,
the issues is still happen with each kind of browsers and settings. Firmware is 5.0...
Hi @Zaddel
I suggest you upgrade firmware to 5.10 by FTP.
There is FAQ teach you upgrade FW by FTP.
https://businessforum.zyxel.com/discussion/649/how-to-upgrade-firmware-to-controller-access-point-by-ftp#latest
Kathy0 -
Ahoi Kathy,
upgrading the firmware solved the Problem, cheers
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 919 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 926 Nebula FAQ
- 422 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
