SecuExtender Routing table
when the SSL is connected I lose my internet connection and I can't use the VPN connection. As I lose the connection the SSL drops after a couple of seconds.
I analysed the windows routing table and I notice that the default route is missing. Does anybiody already has a similar issue?
Best regards
@dpipro
Can I know did you enable "Force all client traffic to enter SSL VPN tunnel"? If so, you can reference the setting steps as below link
https://www.youtube.com/watch?v=r01NWVEnE6E
Hello Charlie, no. This option is disabled. This issue only happens with my wireless adapter. I tried with my laptop connected with a RJ-45 cable and the tunnel works smoothly. Maybe is a compatibility problem with the wireless NIC driver...Zyxel_Charlie said:Best regards0 -
@dpipro
Frimware: v4.39
USG---SSL VPN---(Wireless)PC
On my lab, the PC can established SSL VPN tunnel via Wireless successfully.
- 441 Beta Program
- 292 Service & License
ZCNE Certified
